Re: Cracked Block
Posted by 1953 jubilee on November 11, 2011 at 09:18:20 from (24.179.67.133):
In Reply to: Cracked Block posted by Livin the Dream on November 10, 2011 at 06:04:41:
Livinig The Dream--the guys have already mentioned JB Weld, but I used JB Waterweld on my Jubilee that had a crack that ran around the outside of the block following the oil filter casting. Cleaned it with brake parts cleaner and worked the "dough" into the crack all the way around. Took some sandpaper and pressed it into the drying dough to give it texture. Removed the sandpaper and let it set for 24 hours. Painted it and its held for 5 years so far and you can hardly see the fix. The Jube gets a hard workout bush hogging over Wilson County Tennesse Limestone so it isn't just sitting in the barn. Best of all, didn't have to drain the radiator as that stuff works well wet! Hope you get yours fixed without having to tear it down!
