Re: Visual perspective on the X40 series Farmall
Posted by Wardner on November 11, 2011 at 16:19:29 from (4.154.234.177):
In Reply to: Visual perspective on the X40 series Farmall posted by TMonton on November 11, 2011 at 14:52:28:
The 660 shares that visual imbalance. Its radiator is 3" taller than an International 560. To make the sheet metal fit, a cast iron spacer under the radiator frame and another that is half as high under the forward gas tank mount are necessary. The instrument panel on both tractors sit at the same height.
If it is bothersome, put some Cub front tires on the front wheels.
When Farmall stopped running the steering shaft over the engine, it took the stylists a while to reconcile the unbalanced look.
