If you had dist bushings worn that bad I suspect the adapter housing that dist bolts to is worn where oil pump shaft comes up through to drive distributor. Not uncommon in those models. When oil pump is bolted in, the shaft must be free with no pressure against side of shaft and you often times have to tighten and loosen it a few times to get it centered properly with a free shaft and backlash between drive gear and gear on cam. The adapter housing just drives out of the block with a light press fit. Oil pump shaft is probably damaged as well, bent or worn or both.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
