Re: Cracked Block
Posted by Jim Becker on November 11, 2011 at 21:02:11 from (71.252.156.130):
In Reply to: Cracked Block posted by Livin the Dream on November 10, 2011 at 06:04:41:
That is a pretty big crack, it may be a little tricky to get it sealed, especially in the middle where it appears that the upper edge of the crack has pushed out some. However, that crack is pretty low. If you only have the one crack, you are unlikely to have the problems up on top that earlier responses described.
Groove it and patch with JB weld. Keep on eye on the oil and coolant for cross contamination but I would be very surprised if a problem shows up later. This is all based on the one crack being the ONLY crack.
