Re: Tractor Vet- Still no 1206 steering
Posted by Brad Motheral on November 12, 2011 at 20:09:20 from (208.114.178.8):
In Reply to: Tractor Vet- Still no 1206 steering posted by Farmerdoug on November 12, 2011 at 17:08:03:
looks to me like you"ve exhausted most of the easy things to test and check. i think you might have to have another look at the mcv pump itself. you said in your earlier post it pumped oil when turned. all gear pumps will pump a little no matter what their condition, until you put them under pressure. your pump could have a blown seal or badly scored walls, which won"t let pressure build.
only other things might be blocked pickup tube, dirty filter or missing filter tube o-ring.
good luck, Brad
