Re: cracked a piece off the crank pulley off- can it be f...
Posted by Tom Fleming on November 13, 2011 at 03:20:29 from (206.193.250.146):
In Reply to: cracked a piece off the crank pulley off- can it be fixed? posted by NolanJae on November 12, 2011 at 10:35:43:
I on 2 occasions have had broken pulley's repaired. One was with nickel rod and the other was with brass. Both are working fine. Pulley in each case was built up with weld or brass. Chucked in a lathe, and turned back down. Both were also balanced.
In the end, I probably broke even from a $$$ perspective. It all depends upon whether or not you have access to a good welder and machine shop.
