Re: Axle Bearing
Posted by D Slater on November 13, 2011 at 06:32:57 from (184.15.43.202):
In Reply to: Axle Bearing posted by llamraf on November 12, 2011 at 18:31:54:
Yes there is a hole in the axle housing that joins a hole in the transmission. Balls could come out between bull gear and transmission inner wall and go to bottom or be stuck between the axle housing and the outer transmission wall. I would at least pull the pto and see if I could find the balls or pieces, if not found pull the axle housing. If tractor was used with the balls all missing you better check the inside axle bearing anyway.
