Re: Farmall Cub won't Start
Posted by wildbill57h on November 13, 2011 at 07:06:34 from (68.50.61.73):
In Reply to: Farmall Cub won't Start posted by Ortis on November 08, 2011 at 10:22:33:
I am no expert but am also a motorcycle nut. Have a 46 A on tree farm in NY and a 57 cub in my yard in Md. One thing the m/c guys found out from the boat guys is we're being sold junk they claim is gas. I've been told if you take a vile of gas and set it for 10 hrs you can see it breaking down already. Any bike I will have sitting more than a week I try and run out of fuel in carbs so all I'll need to do when I go to use it is change the fuel in tank. Modern mx bike are said to use fresh fuel ( with in days) or may have engine problems. My cub and vintage bikes all get the fuel shut off and run dry. for your fuel tank I would disconnect at carb and run tank out into spare can.(you can use it to start you burn barrel, just be careful. It may not burn in a cub but it will with a match or bic)Always ,always always use fresh gas oh did I mention ALWAYS!
If you can find none ethenol gas it's better and they say it's best to use a lead additive. I use startron starbright( not a lead addition) additive on all my engines. it will kill the bacteria in the ethenol.
Sorry this is so long I'd like to her what others are doing.
bill
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
