Re: CUB clutch
Posted by gene bender on November 13, 2011 at 10:40:06 from (67.55.226.244):
In Reply to: CUB clutch posted by JohnD73 on November 12, 2011 at 20:22:31:
You need to split the tractor to find out the problem as other post says the linkage is hitting the pressure plates fingers there is something wrong and only way to find it is splitting.
