Posted by BoonvilleKid on November 13, 2011 at 15:21:37 from (24.206.167.119):
In Reply to: General Questions posted by stephenscity on November 13, 2011 at 13:37:50:
1. How do you know the trans. is low and needs additional fluid? Check the level plug - on right side of casing, behind right axle and about level with axle. If fluid does not come out there, I would suggest you remove drain plug on bottom of casing VERY SLOWLY to where fluid starts coming out but plug threads are still engaged. If water (not oil) comes out, you'd best drain the whole case, flush with diesel, refill with recommended gearoil. Before you refill, drain PTO house by plus on lower right side. Fill PTO case by plug on top, fill trans. case by plug on top of case-lid, just to the left of the shift lever.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
