Re: Lp head for a farmall 450
Posted by Janicholson on November 13, 2011 at 19:05:23 from (96.24.99.126):
In Reply to: Lp head for a farmall 450 posted by emtiv1099 on November 13, 2011 at 16:21:30:
Thinking of the wild blue yonder, a diesel with its head raised to about 1/4" on a spacer plate shaped like the block would lower the compression to a managable level (you need to do the math, I am proposing a concept)
Then putting a spark plug where the injector prechamber enters the chamber to make it run, then welding shut the compression relief valve openings would make it a gasser.
Add a custom intake and exhaust manifold/header with a turbo, and nasty it would be. Getting a cam ground might be a interesting issue, the diesel cam would work, but is no where near a pulling cam for gasoline. Jim
