Re: 650 stuck throwout bearing
Posted by willL on November 14, 2011 at 01:23:04 from (74.197.45.212):
In Reply to: 650 stuck throwout bearing posted by Ethan Chamberlain on November 13, 2011 at 16:21:59:
Encountered the same thing on my 650 last year. The "stuffing" used to fill the gap between the engine and the flywheel housing came out and MICE got in there and "fowled" up the whole clutch. Filled the whole clutch cavity with nesting material and wheat. Take off the triangle shaped inspection cover (3 bolts) and see if that is the case. May have to split the tractor to loosen up things.
