i'm not sure how similar a B is to my C.. but I think it's the same pulley and cover.
the timing cover seal actually runs ON the pulley inner portion.. thus no washer betwixt them.
perhaps it was a large washer left over from reseating the pullet onto the crank. IE.. a big bolt and some big washers to screw / press the pulley back onto the crank.
I used a piece of 1/2" flat stock cut round and a gr8 1/2" x 4" bolt and a couple washers unde the bolt to plate etc..
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
