Re: Convert A to Super A
Posted by mkirsch on November 14, 2011 at 06:07:04 from (64.80.110.74):
In Reply to: Convert A to Super A posted by equeen on November 13, 2011 at 11:01:32:
The A has an aftermarket/homemade hydraulic pump on it?
Is it on the engine, run by a V-belt?
If so, you can power the Super A's hydraulic block with the aftermarket pump.
The A's front end and the Super A's rear end will bolt right together at the bell housing. That will give you the hydraulic block (aka touch control).
All that's left at that point is to connect the hydraulic pump to the touch control.
There is a hydraulic manifold and lines that run from the pump on the Super A's engine to the touch control. You will need to take that manifold, cut the lines short, and have threaded hydraulic fittings welded or brazed on. Connect the pump to the manifold with hoses.
