Re: New 560 Owner
Posted by pete 23 on November 14, 2011 at 10:50:05 from (74.32.238.142):
In Reply to: New 560 Owner posted by clayshootr on November 14, 2011 at 05:55:13:
After you change the fuel filters, which do affect
fuel pressure, I would check the automatic load
advance and initial static timing. I have adjusted
hundreds of those load advance pumps over the
years and believe me if they are not working like
intended you would swear the engine is in tough
shape. It needs to advance two full marks on
timing window at all NO load speeds and it retards
gradually as you come under load that is why it is
called load advance and not speed advance. Static
timing is 3 degrees before top dead center. Now I
know you don't have a plastic timing window in
your pocket which is what you need to do it right,
but after doing so many I often times just do it
by ear. Above head of pump, and behind governor
housing is a bolt with a lock nut . Nut takes half
inch wrench or seven sixteenths and bolt head is
either 3/8th or 7/16. If you start her up, run it
wide open , loosen the lock nut while holding
bolt, screw bolt in manybe quarter to half turn
and see if it changes it's tune. If not, nothing
lost. Now, I am not talking about those allen
headed adjusing screw for fuel and speeds. Also,
lots of guys just advance the static timing until
it clears up, problem with that is it stays there
under load and that is not correct. There is of
course more to it than this but what I would try
first.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
