Re: Pete23
Posted by The tractor vet on November 14, 2011 at 16:03:39 from (75.19.123.91):
In Reply to: Pete23 posted by Allan In NE on November 14, 2011 at 14:42:42:
Well if the throw out bearing is away from the clutch fingers then it is not the throw out and leads me to think ft. transmission input bearing bearing as that would be the only frontal bearing that would stop turning when you push in the clutch . Or it maybe that the splines on the input along with a bad pilot bearing is throwing the input shaft out of center .
