Re: Stuck MD and Valve Question
Posted by M Diesel on November 14, 2011 at 16:11:16 from (12.24.61.12):
In Reply to: Stuck MD and Valve Question posted by ShaggyM on November 12, 2011 at 07:22:44:
I'll add to that. If it gets towed for pressure, spark plugs out and switched to gas. Lower end bearings are very expensive. I've seen several that didn't survive the ordeal.
