Re: 706 HITCH PUMP QUESTION
Posted by pete 23 on November 14, 2011 at 17:33:40 from (74.32.238.142):
In Reply to: Re: 706 HITCH PUMP QUESTION posted by KY PLow Boy on November 14, 2011 at 16:31:29:
I am talking about the port in rear frame where
you took the pump off. When you put the aux valve
on demand you are blocking flow so any air you
hear leaking is from a problem area. Another
thing with those pumps is the short suction tube
between pump and filter housing. If you want to do
things correctly, you remove the filter and the
retainer filter fits into inside so you can
install the tube after you have the pump bolted
back on tractor but before you tighten it down.
That little lip seal the tube goes through is
usually in need of replacing and can be tricky to
get in without damaging it. I had my own little
driver made for that job. For me it just goes with
a pump replacement or removal job.
