Re: 806 Hitch PumpTest
Posted by Owen Aaland on November 14, 2011 at 18:44:21 from (216.47.34.80):
In Reply to: 806 Hitch PumpTest posted by Poloz on November 14, 2011 at 11:52:12:
If you lost all flow most likely the cause is a stuck relief valve. A blown O-ring will usually still move a cylinder or hitch without a load.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
