Re: F 12 oil pressure
Posted by 36F30 on November 14, 2011 at 19:01:28 from (71.38.172.106):
In Reply to: F 12 oil pressure posted by Shawn MacAnanny on November 14, 2011 at 18:42:13:
Craig45 said: (quoted from post at 19:42:13 11/14/11) Started the F 12 today and the oil pressure was about 2/3 in
the red. It usually is just above the red band in the white.
What could cause this quick drop? Oil quantity is ok. Thanks
Craig
Where to start? How bout easy...try a new filter and while you have it off inside the oil filter base on the bottom is a large brass plug with a screw driver slot in it. Carefully remove that plug, it has a spring and check ball under it. Make sure it is clean, smooth, and shiny and its seat is clean. Next I would try a different oil pressure gauge. Then remove the valve cover and check the center support to see that is not cracked or dumping your pressure on the top end. Next is the check ball and spring in the pump.... requires removal of the oil pan and disassembly of the pump. If you gotta go there you may as well remove the pump and check it for wear, if the gears are shot it will need some repair or replaced with a good used one. Or any one or all of your bearings (rods, mains, or cam) are shot and one of them let go dumping the oil pressure. Disassembly and checking bearing clearances with plastiguage would be next.
This post was edited by 36F30 at 19:04:21 11/14/11.
