Re: 806 Hitch PumpTest
Posted by Poloz on November 14, 2011 at 20:02:34 from (166.147.113.229):
In Reply to: 806 Hitch PumpTest posted by Lmack on November 14, 2011 at 11:52:12:
3pt hitch will not lift the quick hitch at all.
Is the relief valve integrated into the pump? If not, where is it located? Thanks for everyone's help!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
