Re: 1948 super a farmall has a high idle
Posted by Janicholson on November 14, 2011 at 20:18:40 from (96.24.99.126):
In Reply to: 1948 super a farmall has a high idle posted by k nelson on November 14, 2011 at 13:33:54:
Terminology is getting in the way of an answer.
High Idle is the speed of the engine when the throttle is open fully, and there is no load on the engine (clutch in, or neutral).
If the tractor moves when the trans is in neutral, and the rails are in that position, there may be a shifter fork broken or bent not actually taking it out of gear. The trans design has no other option, there is no path for power to wheels if the gears are in neutral. Jim
