Re: Super C Slight Miss
Posted by kenneth house on November 15, 2011 at 08:50:45 from (173.242.241.49):
In Reply to: Super C Slight Miss posted by Stephenscity on November 15, 2011 at 06:42:05:
if the tractor has sit and not ran much, check and make sure that plenty of fuel is getting to the carb. there is a small drain plug on carb, loosen, remove, there should be good gas flow; if not clean cut-off valve beneath gas tank. this usually fixes mine after it has sat for a while.
