Posted by Owen Aaland on November 15, 2011 at 14:17:54 from (216.47.34.80):
In Reply to: D436/dt436 posted by tempola on November 15, 2011 at 10:26:01:
There are several different heads used on the 400 series engines. They vary both in air passages and cooling passages and deflectors.
Camshafts are the same between turboed and naturally aspirated but there are different cams used as engine development progressed. Lobe size and grind contours changed over time. Lifter design also changed as well as lifter bore. Truck engines switched to using roller lifters.
There are probably more differences between early and late engines than there are between T and NA engines.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
