Re: 966 hard to start
Posted by pete 23 on November 15, 2011 at 17:51:03 from (74.32.238.142):
In Reply to: 966 hard to start posted by tbone8 on November 15, 2011 at 16:32:29:
I can't say that I ever heard fuel returning tank on that model, unless you have cap off and ear to tank. I would check the fuel return fitting coming out of the back side of the pump. It should have a small orfice hole in the fitting. This keeps a good head pressure in pump when cranking to fully fill the pumping plunger. Early models had a spring loaded check valve which could fail and work it's way back inside control section of pump and cause run away engine. Saw it happen, threw rod out side knocking pump off tractor so that stopped it. When you use the hand primer pump you should feel a substantial amount of resistance as you are pumping fuel through this small orfice once filters and pump head are full.
