Re: Farmall M Engine Oil Recommendation
Posted by Mike1972chev on November 15, 2011 at 18:56:33 from (99.50.226.7):
In Reply to: Re: Farmall M Engine Oil Recommendation posted by Tom Fleming on November 15, 2011 at 17:46:33:
Thanks Tom,
ANOTHER thing I "harp" on:In the rising cost of petrolium products,grease is STILL cheap !!!!!! A tube of the BEST grease I buy is STILL under$4.00 a tube !!!!!
Whether you are changing oil,or greasing the tie rod ends on your factory wide front end,you are constantly pushing out the contaminants,you are removing dirt/dust/metal/rust/ect from the component.Things that are abrasive to your tractor!
I didnt even bat an eye buying 15 gallons of 90 wt for the gear box on my Super M.It needed to be done !
Keep your fluids good !!!! :)
