Re: Farmall H Water in Oil
Posted by Redfan on August 29, 2000 at 12:31:59 from (203.87.53.9):
In Reply to: Farmall H Water in Oil posted by Mark Schneider on August 29, 2000 at 10:55:13:
We had a similiar problem with our SAWD6 many years ago. We removed the sump, with the radiator full we noticed water dripping from inside one of the sleeves, out past the piston. As a temporary fix, (10 years ) we removed the sleeve, applied some adhesive over the small hole in the sleeve and the block , turned the sleeve around 180 degrees and replaced it. Might work for you Mark. Regards, Redfan.
Post A Followup
: Re: Re: Farmall H Water in Oil
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
