Re: rear wheel seals for M
Posted by mkirsch on November 16, 2011 at 08:17:11 from (64.80.110.75):
In Reply to: rear wheel seals for M posted by farmerkevin on November 16, 2011 at 07:32:24:
Unless you live out in the middle of nowhere, a local CaseIH dealer will be able to help you out. If you can get the part numbers, a bearing and seal shop (there's usually one in larger towns and cities) can cross-reference it for you and sell you a generic seal for much less than CaseIH.
Carter & Greunwald is a CaseIH dealer that will send you the part.
I've dealt with online ordering from Messick's on several occasions. They're another CaseIH dealer.
Both C&G and Messick's let you order directly from the parts book, if the part is available. You look up your machine, drill down to the part, add it to your shopping cart, and order.
