Re: 1066 TA woes
Posted by The tractor vet on November 16, 2011 at 10:15:25 from (75.19.123.91):
In Reply to: 1066 TA woes posted by nathon on November 16, 2011 at 09:56:13:
The snap ring on the valve should touch the nut . And if you are shifting it SLOW that maybe somewhat a problem . have you run any pressure test to see what you have there. Is the dump valve seating all the way . Also it could be that the direct drive clutch maybe leaking or plum wore out . May have leaking o/rings on the tubes Need to have someone pressure test it.
