Re: Update, 966 hard to start
Posted by tbone8 on November 16, 2011 at 14:50:17 from (67.163.95.35):
In Reply to: Re: Update, 966 hard to start posted by mazemeister on November 16, 2011 at 14:28:26:
If the tractor sits for a day, its hard to start. There is thick grey smoke when trying to start. Takes about 30-40 seconds of cranking, turns over plenty fast. When it finally starts, it takes about 20 seconds of sputtering before it runs smoothly and really belches out the grey smoke. As it gets colder, it is a little harder to start. I did try priming the system before starting and it doesn't help one bit. I also checked the timing today, 18° BTC right on the nose.
