Posted by CenTex Farmall on November 16, 2011 at 17:56:23 from (66.168.230.42):
In Reply to: rear wheel seals for M posted by farmerkevin on November 16, 2011 at 07:32:24:
I've been using Timken 417316. Check also for excessive axle bearing play which can cause leaks even with good seals.
With one side blocked up you can pry up on the tire (like checking ball joints on a car) or put a handyman jack under the axle and apply a little pressure and see how much play there is.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
