You don't say if there are any leaks, not flowing but, just damp or wetness at any fittings or gaskets. You also don't say when the filters were last changed . How cold is it? Though I would expect it to start good down to zero without ether or block heaters on if the engine is not worn out. Have you tried a compression test? It sounds like you either have low fuel pressure or low compression both will give gray smoke upon cold start. For batteries you need at least a thousand cca or more if it is cold say below 20 degrees out.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
