Posted by rustyfarmall on November 17, 2011 at 06:21:38 from (216.248.71.224):
In Reply to: FarmallM posted by Mike1972chev on November 16, 2011 at 20:42:14:
Not likely you would notice any difference. There basically is just one outlet from the pump. The port on the right side and the port on the left side are already "teed" off this port, and for what it's worth, the rear port on the left side is an extension of that "tee" connection. By running a single hose to the rear of the tractor and then using a tee fitting to connect both cylinders, you accomplished the same thing as running 2 hoses, but you didn't need to buy as much hose.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
