Re: Farmall Cub Woods Mower Belt Breakage
Posted by Haas on August 29, 2000 at 16:28:35 from (129.37.117.253):
In Reply to: Farmall Cub Woods Mower Belt Breakage posted by Dennis Van Wagenen on August 24, 2000 at 17:44:49:
Something bad wrong! I used to have a 140 with a Woods mower, mowing 4 acres a week. The belt usually lasted 3 or 4 years! And..I didn't treat it very good either. You need to check a manual and make sure you have the belt on correctly. Also, the belt must be really TIGHT! I used to use a hydralic jack to push the tension pulley down to get it good and tight. If the belt is not tight enough so the belt does not slip, it will wear out and break in short order.
Post A Followup
: Re: Re: Farmall Cub Woods Mower Belt Breakage
