Posted by Bill in NJ on November 17, 2011 at 14:23:40 from (4.248.90.145):
In Reply to: F 12 Carb adjustment posted by Craig45 on November 17, 2011 at 12:41:21:
I'm assuming you are talking about the idle mixture screw. This screw adjusts the mixture at idle. Above idle it does nothing. That 2 1/2-3 turns is usually just a guessimate. With the engine running at idle, screw the idle mixture screw in until the engine sounds like it is starving for fuel. Then back it off about 1/4-1/2 turn. It should idle nicely there. If not, you more than likely have a problem with the float sticking or the needle valve not seating correctly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
