Re: a not starting
Posted by Brownie 450 on November 17, 2011 at 15:42:13 from (66.43.241.198):
In Reply to: a not starting posted by Todd Heck on November 17, 2011 at 14:13:14:
Can also be battery cables where they connect to the battery posts. I am assuming you have a "push rod" to the starter switch, which is mounted on the starter frame. If the ground cleaning & checking the battery posts doesn't help, take the starter switch & battery lead loose & try putting the cable end directly to the starter post which was under the switch. If the engine turns over now, you probably have a bad switch. Check that the starter hot post is not loose. If loose, take the starter apart & tighten the nut from the inside.
