Posted by Hendrik on November 18, 2011 at 03:59:14 from (194.53.253.51):
In Reply to: Re: muffler or pipe posted by Janicholson on November 17, 2011 at 18:22:31:
I fully second what Janicholson and CNKS said about hearing loss. There is NO cure, a hearing aid is so so, and leads to social isolation. Beware! Wear hearing protection if the noise level is 80 dBa or higher for more than a few hours. 80 dBa or higher is when you cannot have a normal conversation with someone sitting besides you (like in a car) without raising your voice. HTH, Hendrik
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
