Posted by IH fan on November 18, 2011 at 04:34:07 from (99.95.236.142):
In Reply to: muffler or pipe posted by soundguy on November 17, 2011 at 17:34:56:
Dad always took the muffler off and put in a straight pipe on his C or SC when he was doing heavier work, like plowing or disking, but had the muffler on when cultivating, mowing, raking or whatever... said it had a little more power. I think he just liked the sound because he always put "glass-packs" on his cars. Maybe the straight pipes were the start of my hearing loss.
About noise and ear protection:
Everyone talks about the noise from jet engines as being so bad.... you should walk into a concrete block hydraulic piston pump test cell with 5 or 6 pumps running at 5000psi. I know for a fact it can be over 140db because I have checked it with a decibal meter. Even with molded ear plugs and muffs it wears on you after a while.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
