Re: Dipstick and oil pan petcocks
Posted by S2710 on November 18, 2011 at 16:00:10 from (98.143.227.89):
In Reply to: Dipstick and oil pan petcocks posted by Steve Reed (Mich) on November 18, 2011 at 09:29:38:
I have put several dip sticks on Ms. Just drop the pan and where the boss is just drill at the correct angle and tap it with 1/4 inch pipe tap. Then you screw in a short pipe nipple and find a dip stick and you are set to go. To mark your stick just add the proper amount to get the oil to come out of the bottom petcock and then take a file and make a line on the stick. Add one more quart and make another line then add one more and it should be coming out the top petcock and add one more line. Job done. Can be done easy and at very little cost.
Bob
