Re: Cord wood saw on a Super MD a few questions
Posted by Janicholson on November 19, 2011 at 07:50:22 from (96.24.99.126):
In Reply to: Cord wood saw on a Super MD a few questions posted by Andrew Z on November 18, 2011 at 05:21:35:
General consensus for RPM is between 1000 and 1400 on the saw shaft. Most old saws have a drive pulley that is in the 4 to 6" range, many belt pulleys run in the 1200 to 1300 RPM area. THus if it is overdriven by about 2:1 I would use 1/2 throttle or so. A shaft tach, or a strobe tach is a good item to have on hand, They should not be run at dramatic speeds. especially since the integrity of the old steel is questionable unless magnafluxed. Bearings are often plain journal type and need to be assessed before use. Either plastigauge, or micrometer measuring, or with shims to lock it then measure the shims. .002" to .005 will probably be OK. Lubrication is grease or drip oilers. Keep safe, and watch for crooked wood or knots that can twist the material and cause injury. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
