Re: Setting Points
Posted by old on November 19, 2011 at 11:17:12 from (209.86.226.30):
In Reply to: Setting Points posted by Stephenscity on November 19, 2011 at 10:08:15:
Why work so hard?? I just grab the fan and turn the engine till it is where it needs to be. By far a lot easier to do then the tire trick
