Re: Bought a set of half tracks, need more pads
Posted by Mr. T-Minnesota on November 20, 2011 at 07:21:27 from (68.170.114.158):
In Reply to: Bought a set of half tracks, need more pads posted by Zachary Hoyt on November 19, 2011 at 18:42:45:
Z,
I currently run a set of half tracks, like yours and do not use the idlers. I am using them on a 2N Ford and they work fine. We ran a set on a WD45 Allis for many years in NE Minnesota without idlers and they were much more maneuverable and easy to work with. This should make it possible to use less cleats and be better all around. I had one or two cleats that were cracked and repaired them with quarter by two inch strap steel. The cleats were mild steel and easy to drill to bolt straps to the cleat. Simply wrap the tracks to rear tire and tighten. Good luck!
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
