Re: farmall 400 hyd pump: how to i split it open?
Posted by CNKS on November 20, 2011 at 08:18:30 from (216.144.104.128):
In Reply to: Re: farmall 400 hyd pump: how to i split it open? posted by DerekD400 on November 20, 2011 at 08:10:31:
The "rebuild" kits can be had from CaseIH, but contain only seals and gaskets. Check the oil level in the engine, hyd oil could have leaked past the seal in the pump into the crankcase, making the pump dry. If that caused the whine, then the only solution is another pump, as they basically are not repairable.
