Bobs diagrams do it. Here are some hints: Use a coil that is for 12v with no resistor required, or the original with a mid 60s Chevrolet ballast resistor in its supply line from the Key. From the same supply line run a 14 gauge wire to a marker light (filament type bulb) a 15 ohm 10 watt resistor, or a diode with the band toward Alt. Connect the other end of light or resistor, or diode to terminal #1 on the Alt. Use 10gauge wire from the Alt stud to the amp gauge. Reverse the amp gauge. Put a fuse link into the wire where it attaches to the Starter relay battery connection. 14ga fuse link, or 40 amp plug style fuse holder and fuse. Install the Battery negative ground. Change all bulbs to 12v including the dash illumination bulb. Jim
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
