Does that engine not use glowplugs? I though they did; you should not need any ether if; 1.)The battery is in good shape, holds proper charge, and the battery leads are the correct gauge. 2)Compression is good and valves/pump are adjusted properly. 3)the glowplug system work even a little bit!
A block heater or hose heated really helps too, especially if you can plug it in overnight. I use a small frost plug mounted heater; it helps when it is below 0F.
The starter solenoid, if original, is a good place to look for amperage loss. They corrode and burn the contacts when LOW voltage is applied; always make sure the battery is charged, is what I am saying.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
