Posted by Janicholson on November 20, 2011 at 15:46:42 from (96.24.99.126):
In Reply to: 504 Won't go posted by angus50456 on November 20, 2011 at 10:36:48:
There are several possible answers: Assumption: The tractor does not bog the engine down when letting out the clutch, it just fails to move, and the engine runs allong just fine. The Master clutch colud be without enough friction material to operate. (should have been a symptom for a while unless someone borrowed it and wasted the clutch) The Torsion cushion springs in the clutch disk center can fail (usually with noise and wierd action) but it will not move at that point, or it will not disengage, (keeps moving, not your issue) The splines on the TA input shaft on the disk can be toast letting the disk rotate W/O the shaft. The TA could be broken internally and no power going through it. The TA clutch, and the spargue clutch could be bad. Did the TA work at all? Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
