Re: Using Quick Start IH 504
Posted by pete 23 on November 20, 2011 at 16:16:36 from (74.32.238.142):
In Reply to: Using Quick Start IH 504 posted by keithre on November 20, 2011 at 14:35:49:
If you are using the glow plugs, just remember that at least one intake valve is open part way at all times and you spraying starting fluid right at a red hot glow plug. You can blow the entire intake manifold and air cleaner right off that tractor. If you are not using the glow plugs, you should.
