Re: MD split/engine swap
Posted by Janicholson on November 20, 2011 at 19:24:14 from (96.24.99.126):
In Reply to: Re: MD split/engine swap posted by hatrick on November 20, 2011 at 19:01:44:
not so. The frame rails are on the front side of the rear engine support. The Flywheel is on the other side of it. The engine support plate comes off with the engine. thus the rails must go. You will probably need to remove the dowel pins (with the threads) as well, some come apart, some do not. Put washers (repeatedly)under an appropriate nut to pull them out.
Look at the parts diagram at this link. Put Farmall in the box, then page 3 or find MD, then scroll to Assembly: Diesel engine 044 Crankcase front cover and support Jim
