Re: MD split/engine swap
Posted by D Slater on November 21, 2011 at 04:48:13 from (184.15.44.59):
In Reply to: MD split/engine swap posted by hatrick on November 20, 2011 at 18:35:44:
For saftey when supporting the engine like the picture always use dowel pins and then at least one set of bolts in frame rails to back plate when sliding apart. Do not remove frame rail to back plate support unless engine is supported from above or other. Front engine mount is a slip fit on the front engine cover and can let the engine fall at least down in the frame rails if frame rails are not supported to rear plate or in other ways. Good luck
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
