Re: MD split/engine swap
Posted by mkirsch on November 21, 2011 at 05:10:23 from (64.80.110.74):
In Reply to: MD split/engine swap posted by hatrick on November 20, 2011 at 18:35:44:
You've ignored the front engine support here.
There is no practical way to leave that with the engine rails, due to the front engine pulley needing to be removed first.
If you don't remove the engine rails, you will need to slide the engine off the rails from the back. Is that even possible? I thought the flange on the rear end of the rail covered over the channel.
It is much easier to remove the bolster and front end assembly first, then remove the side rails, then pull the engine off the bell housing with a cherry picker.
